ProjeQtOr free project management software - PHP Illegal string offset 'name' when trying to save attachment. - ProjeQtOr
24 Apr 2015 03:10 #1 by jimbdeath1
Just like the subject says...I try to add an attachment to a project or activity, and it throws this error:
/var/www/projeqtor/tool/saveAttachement.php' at line (199)
2015-04-23 13:39:19 ***** ERROR ***** cause = Illegal string offset 'name'
2015-04-23 13:50:45 ***** ERROR ***** ERROR *****
2015-04-23 13:50:45 ***** ERROR ***** on file
I'm running this with Ubuntu 14.04.
24 Apr 2015 15:32 #2 by babynus
This is due to some debug line that you can remove : in /tool/saveAttachement.php, remove or comment line 199 :
//debugLog("   traitement fichier ".$uploadedFile['name']);
But this should occur only if you have an import error (for instance importing too big file)
24 Apr 2015 18:54 #3 by jimbdeath1
Thanks for the quick reply.
Now I get an error at line 276 when I try to insert a hyperlink.
24 Apr 2015 19:32 - 24 Apr 2015 19:32 #4 by babynus
Strange as I don't reproduce this issue, using Chrome, FF and IE11.
Maybe you're using another bvrowser ?
What is sure is that you should remove all debugLog in saveAttachement.php.
Last edit: 24 Apr 2015 19:32 by babynus.
