ProjeQtOr free project management software - Real work allocation field can't be registered - ProjeQtOr
28 May 2015 11:17 #1 by vporcelli
Hi !
I try to fill in value in real work allocation field for a resource and when i register, the server doesn't respond (the request is still in progress...)
I have to close my browser and open it on again to continue working with Projeqtor.
Data are not registered.
This worked well few days ago and no update has been done on profileof the resource.
Moreover, it works well for other resources.
There isn't any trace in the logs.
Have you an idea ?
Thanks for your feedback !
30 May 2015 23:01 #2 by babynus
It seems you are facing the max_input_vars issue.
Search for "max_input_vars" for hints : you'll have to increase this value in php.ini.
01 Jun 2015 09:05 #3 by vporcelli
Thanks for your answer.
We 've already increased "max_input_vars" to 4000 when we started working with Projeqtor.
We increased value to 5000 and reload Apache but problem still happens :(
It's strange and annoying because it works well for others resources !
01 Jun 2015 09:28 #4 by babynus
Maybe your php also uses suhosin module, you you should also change values for it :
max_input_vars = 4000
suhosin.post.max_vars = 4000
suhosin.request.max_vars =4000
01 Jun 2015 09:47 #5 by vporcelli
We installed suhosin, updated parameters but problem still hapens...
01 Jun 2015 11:14 #6 by babynus
Can you check for error in browser console ?
If not error appears, please try and reproduce and wait several minutes, to be sure you got response from server.
Then check again log file.
You should have either an error in the log or in the browser console.
