ProjeQtOr free project management software - projects are not displayed - Page 2 - ProjeQtOr
13 Jul 2015 15:45 #7 by bsmi
Replied by bsmi on topic projects are not displayed
Good morning Babynus,
What can I do to fix it?
13 Jul 2015 16:05 #8 by babynus
Replied by babynus on topic projects are not displayed
Try and manually return to V4.42 :
update table parameter set parameterCode='V4.4.2' where parameterCode='dbVersion';
Then reinstall V5.0.2 from zip, go to login page : you should see maintenance message.
Clean log file (to be sure)
Connect as admin, and check log file.
The following user(s) said Thank You: bsmi
