ProjeQtOr free project management software - Dates on problems - ProjeQtOr
Dates on problems
24 Jul 2015 14:22 #1 by c.pache
Dates on problems was created by c.pache
Hi !
An issue in my opinion : when you change workflow status, handled and done dates are empty even checkbox is checked.
Thanks you !
Cédric
24 Jul 2015 16:06 #2 by babynus
Replied by babynus on topic Dates on problems
Please detail your use case.
This description is not precise enough to analyse a potential issue.
27 Jul 2015 19:57 #3 by c.pache
Replied by c.pache on topic Dates on problems
Ok. On Problems screen, when I click on the button to change workflow status (the button on the right of the state field), the date on handled or done field stay empty, even if the chekbox on the left is checked. I think one click on this button have to check thoose boxes and fill thoose date fields but I can be mistaking. I have to fill dates manually.
28 Jul 2015 09:47 #4 by babynus
On Problems screen
do you mean "Issue" screen ?
Only on this screen ?
I cannot reproduce.
Please give more hints.
Any error in the browser console ?
Any error in the log file ?
Please provide print screen.
28 Jul 2015 14:27 #5 by c.pache
Sorry you're right, I mean issue screen (bad translation...).
I tested pushed my investigation and the issue was from me : I created another type of issue, and didn't checked de right boxes on the behavior section...
Sorry
30 Jul 2015 12:16 #6 by c.pache
I come back with my problem. It works great on Issues screen but not on tickets.
When I select the workflow state in the dropdown list, dates are written in the right place. But when I click on the button, the date appears a few seconds, then dissapear.
I think the configuration is now ok in ticket type screen but still don't work. You can see that on screenshots joigned.
Nothing on log file, nothing on console.
