ProjeQtOr free project management software - Ressource not displayed - ProjeQtOr
12 Aug 2015 19:09 #1 by bsimon
On the plannig view, I've added the ressource column and the ressource aren't displayed even I activate the "montrer les ressources" (view ressources) checkbox.
It's working, but it will be fine that the ressource comluns was filled when visible and tio apply "montrer les ressources" on teh gant chart... (may be it's an evolutioin proposal and not an issues).
12 Aug 2015 22:38 #2 by babynus
Replied by babynus on topic Ressource not displayed
I think you left default configuration : resource display = initials.
IF you don't defined initilas for resource, you cannot see anything.
So just define initiales or change parameter (in global parameters)
13 Aug 2015 10:02 #3 by bsimon
Replied by bsimon on topic Ressource not displayed
- Initials are defiend for each ressources.
When checkbox is checked, ressources are displayed on gannt chart & in ressource colomn, and desapear both when checkbox is off
Same beahvior with Firefox/IE
If needed I can make a screen capture or a video capture.
13 Aug 2015 10:58 #4 by babynus
OK, I did not catch the real issue.
So request is to show resource in tabular view, even if not displayed in gantt view.
REquest recorded as Ticket #1783
