ProjeQtOr free project management software - [SOLVED] Bug on Gantt chart - Page 2 - ProjeQtOr
18 Aug 2015 18:20 #7 by babynus
Replied by babynus on topic Bug on Gantt chart
Got it :woohoo:
The project is simply not planned :silly:
Why :ohmy:
Most possibly because "fixed planning" is checked :whistle:
I just tried with single project with "fixed planning" checked, and got same result as yours : "planning calculated in 0 seconds", in pink background.
18 Aug 2015 21:15 #8 by jotrong
Replied by jotrong on topic Bug on Gantt chart
Thank you very much for your solution.
So I just need to uncheck "fix plan" and see the result.
By the way, "fix plan" is for static planing?
Many thanks
jotrong
18 Aug 2015 21:42 - 18 Aug 2015 21:43 #9 by babynus
Yes "fix plan" is to be sure you will not change the planning.
Very usefull when you plan a group of projects. For instance, if you have a project with several sub-projects, you can fix one on the sub-project and replan all the others running planning on parent :)
Last edit: 18 Aug 2015 21:43 by babynus.
