ProjeQtOr free project management software - [SOLVED] When copying as new element, elements are not correctly alphabetically sorted - ProjeQtOr
20 Aug 2015 14:39 - 21 Aug 2015 11:13 #1 by papjul
As you can see in the screenshot, elements are sorted according to the key and not the value, which is why Invoice (which I renamed from Bill) and Order (renamed by you from Command I guess?) are not in the right position (which makes me also think that in other languages it's not sorted at all). I don't know in which file you fetch a list of elements but an asort($array) should fix this ;)
Thank you,
Last edit: 21 Aug 2015 11:13 by papjul.
21 Aug 2015 13:44 #2 by babynus
Recorded as Ticket #1790
Thanks for pointing out
