ProjeQtOr free project management software - Planing not loading - ProjeQtOr
Planing not loading
16 Sep 2015 19:45 #1 by soyelsimo
I have 2 projects, I changed their substructure of subprojects and subactivities. They had 3 subproyects and inside of each one several activities. And now the projects has several subprojects with 3 or 5 sub activities inside.
When I modify one of the mother projects It still worked fine. When I modified the second one is when I got this alert on planing window. Resource planing seems to work fine.
16 Sep 2015 20:21 #2 by soyelsimo
Replied by soyelsimo on topic Planing not loading
Well I see that this happends only when I try to load planing for all projects. When I load one project and its subprojects and subactivities planing loads
16 Sep 2015 21:22 #3 by babynus
Replied by babynus on topic Planing not loading
This is not an issue but a limitation : when you display planning for all projects, display is blocked if number of projects to display exceeds a given number.
This limitation has been applied to avoid Browser freeze (and possibly crash).
You just have to select a project to limit display to this project and its sub-project.
If you have small projects (with less than 10 lines per projet for instance) you can change this limitation in the Global Parameters screen to allow display of more projects. Just take care about possible effects depending on browser capacity.
The message "selectProjectToPlan" seems not to be a good translation for "Max Projects to display exceeded. You must select a project".
A new translation has been proposed for V5.1 : "Seleccionar Proyecto", more explicit but possibly not complete (sorry I don't speak spanish).
If you can propose a better translation, please do ;)
16 Sep 2015 23:08 #4 by soyelsimo
ok I see, thought I messed up something. Yes a better alert message will help to solve this confusion. I propose:
"Seleccione un proyecto. Maximo de proyectos para mostrar excedido"
"Select a project. Max projects to display exceeded"
Hope is not too long, spanish always is longer than english.
Thank you very much!!
17 Sep 2015 08:31 #5 by babynus
Your translation proposale you appear in V5.1
Thank you
