ProjeQtOr free project management software - Tickets 1629 & 1630 issue - ProjeQtOr
05 Nov 2015 09:15 #1 by c.pache
Hello !
I have noticed something : The new function that automaticaly change status to done when left work = 0 and to in progress when a charge is entered doesn't work for me.
I translated status in french because some user don't speak english here. So done = fait & in progress = en cours. I imagine it can be the reason, can you confirm please ? Have you got a solution ?
Thanks for your answer.
Cédric
05 Nov 2015 11:27 #2 by babynus
Replied by babynus on topic Tickets 1629 & 1630 issue
No, there is absolutely no impact on translation of status names (I also have translated names to french :whistle: ).
You can also add status, if status is cheched for "done status" it will be taken into account.
First check that workflow allows you to change item from current status to some "done status" (status with checkbox "done status" checked).
Also check you have rights to modify the activity.
