ProjeQtOr free project management software - Project visibility not the same in "Today" and in "Project" view - Page 2 - ProjeQtOr
28 Jan 2016 09:56 #7 by stephane.pelletier
Thanks. Even in that case the project leader can only consult the data of the project and can not modify it although he should (because he is the project leader which mean that he should have rights to modify "elements of own project".)
All happens as if the Affectation on this project was not done properly. ProjeQtor does not interpretate the assigned profile of "Project Leader" and does not display data to my project leader (or displays the data in consultation only if I change the parameter "Manager" as you suggest)
29 Jan 2016 09:11 #8 by babynus
Would need print screen of "Access to data (project dependant)" to investigate.
29 Jan 2016 09:26 #9 by stephane.pelletier
Please see screen shots attached.
Again, the difficulty is that it is not systematic to all projects. In all cases: project leaders can see there projects in "Today" view. The issue comes in the "Projects" view and all related views (Activities, Affectations, ...)
regards
This browser does not support PDFs. Please download the PDF to view it: Download PDF
29 Jan 2016 09:54 #10 by babynus
OK, access rights are correct (default values).
Can you show rpint screen of affectations (from user screen), 1 for Project leader running fine, one for roject leader with issues.
29 Jan 2016 14:05 #11 by stephane.pelletier
here it is
29 Jan 2016 14:19 #12 by babynus
Thanks for print screen, it is much more clear with it... :)
Look at affectation details... :huh:
Affectation to visible project ends on april 2016. :unsure:
Affectation NOT visible is ended since end of decembre 2015 : so it is normal to hide the project.
The resource is considered not affected any longer :woohoo:
The following user(s) said Thank You: stephane.pelletier
