ProjeQtOr free project management software - Technical issue occured possibly due to bad network connection - Page 3 - ProjeQtOr
25 May 2017 15:13 #13 by gulsum
Our server is test server and runs on intranet so we switched off firewall. We don't use Proxy also:(
25 May 2017 15:14 #14 by gulsum
Nothing on apache log except from missing promise directory.
25 May 2017 17:54 #15 by babynus
Try and increase the output_buffering size in php.ini
It may be the source of output truncation (and V6.2 uses buffering that was not used before)
26 May 2017 09:55 #16 by gulsum
Increased the buffer size. Now the error changed:
It says: ERROR : An error occurred on 2017-05-26 at 10:50:52
In projector error log:
2017-05-26 10:45:52.072 ***** ERROR ***** [V6.2.4] on file '/srv/www/htdocs/projeqtor/view/objectDetail.php' at line (4510)
2017-05-26 10:45:52.072 ***** ERROR ***** [V6.2.4] cause = ob_get_clean(): failed to delete buffer zlib output compression
No error log for apache nor browser console.
26 May 2017 10:10 #17 by gulsum
I set zlib.output_compression off and it works now!
26 May 2017 10:17 #18 by babynus
GREAT !!!!
So it was an output_buffering issue...
