ProjeQtOr free project management software - SMTP connect() failed. - ProjeQtOr
25 Oct 2017 19:16 #1 by adali
SMTP connect() failed. was created by adali
I did three installation of projeqtor for test, once under windows7 32bits, another in windows 10 64 bits and last one in windows server 2013 64 bits, in fisrt case when I setup email it's work fine except for the two latest cases, may someone could help and am I wrong to my undestanding of the issue regarding windows 32 and 64 bits
Best regards
25 Oct 2017 19:29 #2 by babynus
Replied by babynus on topic SMTP connect() failed.
Under windows, you must use remote SMTP server.
There is no local SMTP server like existing on linux.
25 Oct 2017 19:50 - 25 Oct 2017 19:52 #3 by adali
Replied by adali on topic SMTP connect() failed.
I setup a remote SMTP server in three cases
Last edit: 25 Oct 2017 19:52 by adali.
26 Oct 2017 00:16 #4 by babynus
Connection fails.
try and force protocole adding ssl:// or tls:// before smtp server name and check password...
26 Oct 2017 00:22 #5 by babynus
Also try with port 995 which appears on ovh user guide, or 587 with TLS
26 Oct 2017 00:23 #6 by babynus
and also check that ssl module is enabled on your PHP server (checl projeqtor log file and apache error log file)
