ProjeQtOr free project management software - admin pwd don't work after online hosting - ProjeQtOr
12 Nov 2017 15:01 #1 by Lunch
Dear all,
i have an existing website working perfectly
i created a sub-domaine inside to host Projeqtor
i have copied projeqtor files inside the folder properly
for the installation i have used the same database of the existing website
i can see the projeqtor interface display well but i can't get acces with admin/admin
please i need your help
12 Nov 2017 15:05 #2 by babynus
Try and clean cache and cookies
12 Nov 2017 15:55 #3 by Lunch
Thank you for your faster response, i have cleaned cache and cookies of my browser but it still not working, see attached file; please can you help?
Thank you
12 Nov 2017 16:40 #4 by Lunch
I got a log file:
2017-11-12 15:45:24.151 ***** ERROR ***** [] ERROR *****
2017-11-12 15:45:24.152 ***** ERROR ***** [] on file '/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/tool/projeqtor.php' at line (2797)
2017-11-12 15:45:24.153 ***** ERROR ***** [] cause = set_time_limit(): Cannot set max execution time limit due to system policy
2017-11-12 15:46:53.885 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'atezcorporation.parameter' doesn't exist
2017-11-12 15:46:53.886 ***** ERROR ***** [] For query : select * from parameter where (idUser is null and idProject is null)
2017-11-12 15:46:53.887 ***** ERROR ***** [] Strack trace :
2017-11-12 15:46:53.887 ***** ERROR ***** [] #0 Sql->query called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2255]
2017-11-12 15:46:53.889 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/Parameter.php:895]
2017-11-12 15:46:53.890 ***** ERROR ***** [] #2 Parameter->getGlobalParameter called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/UserMain.php:139]
2017-11-12 15:46:53.891 ***** ERROR ***** [] #3 UserMain->__construct called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/User.php:38]
2017-11-12 15:46:53.892 ***** ERROR ***** [] #4 User->__construct called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/tool/projeqtor.php:2939]
2017-11-12 15:46:53.893 ***** ERROR ***** [] #5 getSessionUser called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/tool/projeqtor.php:155]
2017-11-12 15:46:53.894 ***** ERROR ***** [] #6 require_once called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/view/main.php:37]
2017-11-12 15:47:30.740 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'atezcorporation.resource' doesn't exist
2017-11-12 15:47:30.742 ***** ERROR ***** [] For query : desc resource
2017-11-12 15:47:30.742 ***** ERROR ***** [] Strack trace :
2017-11-12 15:47:30.743 ***** ERROR ***** [] #0 Sql->query called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:3255]
2017-11-12 15:47:30.744 ***** ERROR ***** [] #1 SqlElement->getFormatList called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2836]
2017-11-12 15:47:30.744 ***** ERROR ***** [] #2 SqlElement->getDataType called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2218]
2017-11-12 15:47:30.745 ***** ERROR ***** [] #3 SqlElement->getSqlElementsFromCriteria called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2489]
2017-11-12 15:47:30.746 ***** ERROR ***** [] #4 SqlElement->getSingleSqlElementFromCriteria called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/tool/getHash.php:48]
2017-11-12 15:47:30.747 ***** ERROR ***** [] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'atezcorporation.resource' doesn't exist
2017-11-12 15:47:30.747 ***** ERROR ***** [] For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2017-11-12 15:47:30.748 ***** ERROR ***** [] Strack trace :
2017-11-12 15:47:30.749 ***** ERROR ***** [] #0 Sql->query called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2255]
2017-11-12 15:47:30.750 ***** ERROR ***** [] #1 SqlElement->getSqlElementsFromCriteria called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/model/persistence/SqlElement.php:2489]
2017-11-12 15:47:30.751 ***** ERROR ***** [] #2 SqlElement->getSingleSqlElementFromCriteria called at [/customers/3/1/7/atezcorporation.com/httpd.www/acelmgmt/tool/getHash.php:48]
12 Nov 2017 17:26 #5 by babynus
It seems acces to database is not correct.
Check config in parameters.php file.
12 Nov 2017 21:14 #6 by Lunch
Here is my parameters.php
<?php
// Automatically generated parameter file
$paramDbType = 'mysql';
$paramDbHost = 'atezcorporation.com.mysql';
$paramDbPort = '3306';
$paramDbUser = 'atezcorporation';
$paramDbPassword = '##########';
$paramDbName = 'atezcorporation';
$paramDbDisplayName = 'projeqtor';
$paramDbPrefix = '';
$SslKey = '';
$SslCert = '';
$SslCa = '';
$paramLdap_allow_login = 'false';
$paramLdap_base_dn = 'dc=mydomain,dc=com';
$paramLdap_host = '127.0.0.1';
$paramLdap_port = '389';
$paramLdap_version = '3';
$paramLdap_search_user = 'cn=Manager,dc=mydomain,dc=com';
$paramLdap_search_pass = 'secret';
$paramLdap_user_filter = 'uid=%USERNAME%';
$paramMailSender = '';
$paramMailReplyTo = '';
$paramAdminMail = '';
$paramMailSmtpServer = '127.0.0.1';
$paramMailSmtpPort = '25';
$paramMailSendmailPath = '';
$paramDefaultPassword = 'projeqtor';
$paramPasswordMinLength = '5';
$paramDefaultLocale = 'fr';
$paramDefaultTimezone = 'Africa/Douala';
$currency = 'XAF';
$currencyPosition = 'after';
$paramFadeLoadingMode = 'true';
$paramIconSize = '22';
$defaultTheme = 'ProjeQtOrFlatBlue';
$paramAttachmentDirectory = '../files/attach/';
$paramAttachmentMaxSize = '2097152';
$paramReportTempDirectory = '../files/report/';
$paramMemoryLimitForPDF = '512';
$logFile = '../files/logs/projeqtor_${date}.log';
$logLevel = '2';
Time to create page: 0.076 seconds
