ProjeQtOr free project management software - Invalid Login Parameters - Page 3 - ProjeQtOr
07 Dec 2018 10:23 #13 by emmanoueli
Replied by emmanoueli on topic Invalid Login Parameters
Ok, I found that your parameter table refers as dbVersion v0.0.0 and my XAMPP set has installed 10.1.37-MariaDB - mariadb.org binary distribution.
What the content of dbVersion should be ?
07 Dec 2018 10:28 #14 by babynus
Replied by babynus on topic Invalid Login Parameters
It should content version of ProjeQtOr (V7.2.7 or V7.3.1)
07 Dec 2018 12:52 #15 by emmanoueli
Thank you , I am IN!!! :)
18 Jul 2024 21:51 #16 by berthelemy
Replied by berthelemy on topic Invalid Login Parameters
I have just had exactly the same problem with version 11.3.1
After a clean install, when I try to login with admin/admin I get "invalid login credentials".
In the parameter table there is no line for dbVersion. When I add that line with the entry V11.3.1 I am able to login.
Why does this issue occur?
19 Jul 2024 18:51 #17 by babynus
It seems your install was not complete.
Check errors loggued
Try new install
