ProjeQtOr free project management software - Global Parameters/Mailing - parameters not saved when clicking on "save" button - ProjeQtOr
23 Jan 2019 13:02 #1 by esther
I am trying to set up the mailing parameters in my projeqtor installation.
Under Global Parameters, under Mailing section. If I setup one of the parameters (smtp server, email of administrator, etc.) and click on save, then when I go back to this section, parameters are gone.
Even without clicking on save, if I edit the parameters and click on "send test", it throws an error mentioning old parameters.
Is this a known issue? Is this not the right way to setup mailing parameters?
Many thanks
24 Jan 2019 16:54 #2 by babynus
Possibly the parameters are also stored on fiel parameters.php.
Remove the parameters from the file, you'll get correct behavior.
24 Jan 2019 16:57 #3 by esther
OK, will try that.
But don't you think this problem should be fixed in a further version ?
