ProjeQtOr free project management software - Projects Missing - ProjeQtOr
Projects Missing
10 Apr 2019 18:17 #1 by piper8
Projects Missing was created by piper8
Most of my projects are missing from the projects screen. All of them do show up in the "today" screen, and if I click one there, it then shows up in the projects screen,, at least for a while. The Projects table in MySQL looks ok, I'm not sure if this is database corruption that I'm just not seeing, or something else. Is there a way to pull logs that would be helpful, or does someone have any other advice in troubleshooting this? This happened after my computer shut down improperly (the servers are on this machine as well.) The activity I've created doesn't show up in activities either.
10 Apr 2019 18:26 #2 by babynus
Replied by babynus on topic Projects Missing
Try and repair your db.
You can use mysqlcheck for instance (search the web for help)
10 Apr 2019 18:40 #3 by piper8
I ran a check on the full projeqtor database, all tables are good.
I tried repair, and get "The storage engine for the table doesn't support repair" apparently this is InnoDB, which doesn't support repair. Optimize did a recreate+analyze, which completed successfully.
10 Apr 2019 18:44 #4 by piper8
Replied by piper8 on topic Projects Missing
The problem still exists unchanged after these actions, to be clear.
Thank you
10 Apr 2019 22:08 #5 by babynus
Mybe you can try export (dump) db and reimport (with new name) and use new db.
Also try consistency check in Adlinistration screen.
11 Apr 2019 16:33 #6 by piper8
Thank you again. I tried exporting the database, then creating a new one with a different name and importing into it, the problem remains as before. I also did a consistency check earlier, no problems were found.
