ProjeQtOr free project management software - Clone Environtment - Only for selected projects - ProjeQtOr
04 Feb 2020 09:55 #1 by javierrm
Is posible include on the popup windows to create the clone environment a list with all projects, and then we can select the projects to include on the environment cloned.
It'ss posible or are planned can do it only with the selected projects?
04 Feb 2020 10:45 #2 by Damian.sd
we cannot do that, environment cloning its used for clone your actual projeqtor environment with all parameters and objects you have on this.
We have much constraint to clone only one project.
The following user(s) said Thank You: javierrm
04 Feb 2020 11:58 - 04 Feb 2020 12:00 #3 by alainforma
In my opinion, it seems unskilful to plan ( with simulation) only some projects because on reality those projects will impact the others one. It is better to analyse that on simulation. That is why all projects are taken in consideration without selection.
Last edit: 04 Feb 2020 12:00 by alainforma.
04 Feb 2020 12:14 #4 by javierrm
What I am looking for is to have a complete photo of a project at a certain time (to have still photos of baselines that I need for CMMI level 3), and with the cloning of the environment, it seems like a great solution, but it would be better if it were only at the project level and not the entire environment. That is why requesting this function.
04 Feb 2020 12:18 #5 by babynus
Your need is covered with baseline management.
Have a look at user manual.
04 Feb 2020 12:22 #6 by javierrm
this only take a photo of planning,,no? we need a photo of planning, risk, problems, actions, requirements, etc.
