ProjeQtOr free project management software - Ticket#275 - possible solution - ProjeQtOr
26 Apr 2012 12:48 #1 by climb4fun
Hi Babynus,
there is an old request from me - Ticket 275 "Empty database but keep parameters".
Now, knowing better projectorria, I suggest, to solve in the way, to have a dump function for all parameter tables and a import function. Could be locate under Tools - export / import parameter files.
Klaus
26 Apr 2012 13:49 #2 by babynus
Hi Klaus,
I updated the ticket with your suggestion.
It may be a good idea to be studied, but must be fully analysed :
- what will happen if the function is used on a full datadase ?
- should existing parameters be deleted before import ?
Regards.
26 Apr 2012 15:00 #3 by climb4fun
Yes, a serious problem. I would say, a simple warning message for executing should with an explizit OK button should be sufficient.
From my pov yes, tables should be TRUNCATED before new paramenters will be inserted.
Basic reasons for using this function are:
1. Have errors after modifying parameters, to quickly go back to a stable version of parameters. A full database restore will overwrite all non parameter values as well.
2. Setting up a complete new instance of projectorria and loading "good practice" values in new instance.
