ProjeQtOr free project management software - Requirements management - ProjeQtOr
23 May 2012 13:55 #1 by ekolossov
I think it is now time to add requirements management to the projectorria. It will make tool even more useful. Actually it suppose to be very similar to ticket with the links as it done for ticket.
The next step can be test cases management related to the requirements.
If you can come up with reasonable estimate I can probably find some funding for this implementation
Evgueni
28 May 2012 21:33 #2 by babynus
Replied by babynus on topic Re: Requirements management
Hi Evgueni,
This evolution is not planned to come soon.
If you can find some funding, maybe you can use the new service : developement of evolution on request.
You will find details of this service on the "Service" menu.
As the evolution is estimated to 3 man*day, you will easily calculate cost, and you'll then determine if you concider it as reasonable.
Don't hesitate to contact me for more information.
Regards.
Babynus.
02 Jun 2012 18:29 #3 by spiderjn
Hi All,
Requirements management is also a need I have in my use of Projectorria, for now I created a new type of ticket.
I am also interested to finance the development.
Babynus, can you describe your proposed implementation of this feature?
Best Regards
03 Jun 2012 23:55 #4 by babynus
Implementation planned to add item much like tickets.
With possibility to expand.
Any suggestion welcome.
Here is a possibility :
New screen "Requirement Type" :
- name
- code
- code
- workflow
- description : mandatory
- responsible : mandatory on handled status
- result : mandatory on done status
- lock handled : handled must be changed by status
- lock done : done must be changed by status
- lock closed : closed must be changed by status
- sort order
- closed
New sceen "Requirement" :
- Description
- id / reference
- project
- product
- product version
- type
- name
- external reference
- creation date/time
- description
- Treatment
- parent requirement
- status
- responsible
- handled
- done
- closed
- target version
- result
- Linked Elements
(link to any element : activity, document, ...)
- Attachments
- Notes
Regards.
04 Jun 2012 13:54 #5 by spiderjn
Hi babynus
like i exchange with you in past, you can take a look at Jira implementation for this subject :
docs.optimizory.com/display/rmsis0130/Requirement+Attributes
from my point of view, you can add :
Estimated Effort : in man days
Priority: This field specifies priority of the requirement. Possible values for this field are "Blocker", "Critical", "Major", "Minor" and "Trivial".
Criticality: This field specifies criticality of the requirement. Possible values for this field are "Low", "Medium" and "High".
Feasibility:This field specifies technical and business feasibility of the requirement. Possible values for this field are "Yes", "No" and "Investigate".
Best Regards
04 Jun 2012 15:56 #6 by babynus
Thanks for this reminder.
I'll include it in the planned devs.
