ProjeQtOr free project management software - Project Indentation on Project Screen - ProjeQtOr
11 Jul 2014 16:11 #1 by francis2301
I'd like to propose that in the project screen the same concept of indentation used in Today Screen, Project List Combobox.
I mean, SubProjects should be shown right below their parent projeqt with indentation.
Example
Project1
Project2
Project3
SubProject1
SubProject2
Projeqt4
I think it would facilitate the visualization of parent/child projects
11 Jul 2014 16:35 #2 by babynus
This evolution has already been proposed but been rejected : as this list is sortable by any column, indentation would mean nothing.
Only planning view can give correct wbs structure.
09 Sep 2014 17:00 #3 by gt
Hi
I want to know how wbs work, because I tried to modify in cvs all values, including id and subproject, but when upload it to the server, I see different numbers that are not the same as initial cvs values.
Furthermore, when I update any project, I see that sub projects and wbs are not connected, because I have two categories (projects) but with the same activities (Subproject), so, when I upload csv, the activities (subprojects) are moved to the first category (project) and the other category become empty
09 Sep 2014 17:36 #4 by babynus
WBS represnets the postion in the structure of project.
WBS is recalculated :
- on item creation
- on project change
- on parent change
- on move (on planning view)
So WBS on import file will no be taken into account.
09 Sep 2014 17:54 #5 by gt
Thanks, I just have one more question, to reset all indentation and update project with cvs, how can I erase multiple projects?
09 Sep 2014 18:08 #6 by babynus
Move them all under one parent project.
Delete parent project.
