ProjeQtOr free project management software - Recalculation Auto - ProjeQtOr
Recalculation Auto
30 Nov 2015 15:24 #1 by El Wallos
Recalculation Auto was created by El Wallos
Hi
It could be a good idea to have a check box to recalculate automaticaly the planning after any update. I think this check box could be useful at project level.
01 Dec 2015 08:23 #2 by babynus
Replied by babynus on topic Recalculation Auto
This button already exists in the planning view.
Can be used for instance when you build your project.
To have global calculation on each change, it is a bit more complex than a single button.
But request already exists : Ticket #1815
01 Dec 2015 09:36 #3 by El Wallos
Replied by El Wallos on topic Recalculation Auto
babynus wrote: This button already exists in the planning view.
Could you give me more detail about this way?
babynus wrote: To have global calculation on each change, it is a bit more complex than a single button.
No doubt it is not easy :silly: Your work and your project is awesome.... Thanks again for your help
01 Dec 2015 10:43 #4 by babynus
Just go to the planning view, check the checkbox "automatic run plan" and make any change on activity. You'll see what happens.
01 Dec 2015 15:27 #5 by El Wallos
I'm working on v5.0.6, is it enable? because i didn't found it.
01 Dec 2015 15:31 #6 by babynus
No.
New on V5.1
