ProjeQtOr free project management software - [SOLVED] Add SSL settings for mysql PDO connection - ProjeQtOr
02 Sep 2016 12:48 #1 by desperados
Hi everybody !
My MySQL connection requires SSL. So, i modified these two files :
/usr/share/projeqtor/projeqtor/model/persistence/Sql.php at line 280 :
self::$connexion = new PDO($dsn, self::$dbUser, self::$dbPassword,
array(
            \PDO::MYSQL_ATTR_SSL_KEY    =>'/path/to/my/client-key.pem',
            \PDO::MYSQL_ATTR_SSL_CERT=>'/path/to/my/client-cert.pem',
            \PDO::MYSQL_ATTR_SSL_CA    =>'/path/to/my/ca-cert.pem'
/usr/share/projeqtor/projeqtor/tool/configCheck.php at line 87 :
$connexion = new PDO($dsn, $param['DbUser'], $param['DbPassword']
array(
and at line 108 :
        $cnxDb = new PDO($dsn, $param['DbUser'], $param['DbPassword']
array(
At each update, i have to modify these files.
Can you take in consideration this point in your future evolutions ?
Jordan LE NUFF
IT Project Manager
02 Sep 2016 12:51 #2 by babynus
This is subject of Ticket #2046, planned on V5.6
The following user(s) said Thank You: desperados
