ProjeQtOr free project management software - [SOLVED] summary of availability rapport negative or null for pool - ProjeQtOr
09 Jul 2019 12:10 #1 by pipobru
with the las t version (8.1.0) for pool of ressources, availability are null without affection (no charge) and negative if a charge are planned. See scren in attachement. may be the bug #4035 is not fuly efficient ?
09 Jul 2019 12:19 - 09 Jul 2019 12:20 #2 by babynus
It is normal.
It is to have correct SUM for each column (month).
Availability of Pool is already counted as availability of resources in the pool.
So all planned work on pool is something that will decrease availability of resources (but we don't klnow wich, it can be any of the resources of the pool).
Last edit: 09 Jul 2019 12:20 by babynus.
The following user(s) said Thank You: pipobru
09 Jul 2019 12:23 #3 by pipobru
