ProjeQtOr free project management software - Screencustomization does not work since many Projeqtor updates - ProjeQtOr
01 Aug 2019 13:08 #1 by TLamy
Hi!
Projeqtor version: >=7.3.3. ScreenCustomization plugin version V5.3
I want to customize 'Activity - Progress' screen element, for example to change the color of the validated start date field.
When doing that, the validated data get 'read only', some fields move and it's not the right field that has a changed color...
Please see details in the doc file attached.
Thanks a lot for your help!
Thierry
File Attachment:
File Name: bugscreencustom.docx
File Size:467 KB
01 Aug 2019 16:09 #2 by babynus
Hi
This issue is very specific.
It occurs only on "progress" parts (Activity - porgress or else), only if you make some change on validated start date, which is the first field.
The field is improperly moved at an unexpected place.
It is not another field that is "colored", it is this one, but whole structure of table is a mess.
We'll have a look at this.
01 Aug 2019 16:22 #3 by TLamy
