ProjeQtOr free project management software - [SOLVED] How to get specific URL for a Project? - ProjeQtOr
15 Dec 2019 18:07 #1 by coffe1nk
I want to access specific proejct from URL.
How to get URL of a specific project, for example:
https://localhost/projeqtor/project/1
Thanks and regards,
15 Dec 2019 19:02 #2 by babynus
On project screen, on the detail part, click on the id of the project : the url will be highlighted and selected (you can then copy it with CTRL+C)
You can also right click on the id and copy link url
16 Dec 2019 00:15 #3 by coffe1nk
That's great...
one more question, how to get direct URL to Planning page for a specific project?
File Attachment:
Thanks and regards,
16 Dec 2019 11:51 #4 by Flou
It's not possible to get direct URL to Planning page for a specific project.
17 Dec 2019 07:58 #5 by coffe1nk
Hi Flou,
I see..
Thanks and regards,
17 Dec 2019 19:16 #6 by lean-sigma
Hi, to provide an hyperlink to the planning of a projet, I use the Gantt report URL.
To get the URL of a report, select the report you want then click on the print button with the middle button of your mouse. The report is displayed in a new tab. You can copy the URL.
Here is one of mine : http://xxxxxxxxxx/projeqtor/view/print.php?reportFile=..%2Ftool%2FjsonPlanning.php%3Fprint%3Dtrue&reportId=7&idProject=46&startDate=2019-12-17&endDate=&format=month&orientation=L&objectClass=&reportCodeName=PlanGantt&page=..%2Freport%2F..%2Ftool%2FjsonPlanning_pdf.php%3Fprint%3Dtrue&print=true&report=true&outMode=pdf&reportName=planning+de+Gantt
I hope it will help you.
