ProjeQtOr free project management software - Error when calculating planning in view Planning (No data to display) - Page 2 - ProjeQtOr
24 Apr 2020 02:17 - 24 Apr 2020 02:18 #7 by msassi
It seems that reason that you sent to me are not tthe cause of my problem.
I ckecked it one by one in my project but problem is not resolved.
I taked 14 screenshots from differents UI in my ProjeQtor that I thought they could contain the cause of my problem.
Please find in attached a .zip
We choose projeqtor between many are solution because we like too much how planning is calculated.
Hope that we could together find solution for this.
Thank you in advance
Last edit: 24 Apr 2020 02:18 by msassi.
24 Apr 2020 09:04 #8 by babynus
Your resource #3 has capacity (FTE) = 0
It means he can work 0 days per day.
This explains why the planning gives no result.
Chenge Capacity to 1 (standard value) to have planning work.
30 Apr 2020 18:09 #9 by msassi
After following your last mail, we have only one problem resolved. (in relation with timesheet)
Now, colors in timesheet are well displayed ('Green' for all working days with 8 hours and 'Red' for off days).
But, planning calculation still not working !
Any help please. Could you take a look again to all screenshot that I sent in others messages.
Thank you in advance.
01 May 2020 14:43 #10 by babynus
When capacity is fixed, recalculate planning.
If planning is not calculated, check allocation rate to project : it must not be 0 on projct and on parent projects.
01 May 2020 16:30 #11 by msassi
If we well understand "Rate", it's column "Rate" into project/Allocation to project.
Please take a look to screenshots we attached to this ticket and check with us if rate is well done.
Else , we always have doubt that probems are caused by fields into "Dates and durations" into every activity. There are always empty.
But when ressource fills into timesheet and "real time" of activity becomes > 0, planning is well calculated (Look please to screenshots called "Real_time_1.png" & "Real_time_2.png")
02 May 2020 14:17 #12 by babynus
On your screenshot I can see that left work is zero.
So there is nothing more to plan...
