ProjeQtOr free project management software - [SOLVED] Auto saving on task not operational - Page 2 - ProjeQtOr
26 May 2020 10:02 #7 by pipobru
Hello,Thanks for your answer.
I have check and this file have same access rules of all other files. I have tested after an upgrade to the 8.4.4 version and the problem is the same.
26 May 2020 17:57 #8 by babynus
Maybe you'll find more information on your apache log file.
Seach for the 403 error.
27 May 2020 11:12 #9 by pipobru
Thanks i check with my SI departement.
An another trace:
projeqtor.js?version=V8.4.3.0258:179 => 236ms | page='objectStream.php' | destination='detailRightDiv' | formName=listForm' (server:211ms, client:25ms)
ckeditor.js?version=V8.4.3.0258:21 [CKEDITOR] Error code: editor-destroy-iframe.
(anonymous) @ ckeditor.js?version=V8.4.3.0258:21
p @ ckeditor.js?version=V8.4.3.0258:10
(anonymous) @ ckeditor.js?version=V8.4.3.0258:12
CKEDITOR.warn @ ckeditor.js?version=V8.4.3.0258:19
detach @ ckeditor.js?version=V8.4.3.0258:955
CKEDITOR.editor.editable @ ckeditor.js?version=V8.4.3.0258:400
destroy @ ckeditor.js?version=V8.4.3.0258:283
load @ projeqtor.js?version=V8.4.3.0258:1028
(anonymous) @ dojo.js?version=V8.4.3.0258:2
_18b @ dojo.js?version=V8.4.3.0258:2
_189 @ dojo.js?version=V8.4.3.0258:2
resolve.callback @ dojo.js?version=V8.4.3.0258:2
_3fd @ dojo.js?version=V8.4.3.0258:2
_3f7 @ dojo.js?version=V8.4.3.0258:2
resolve @ dojo.js?version=V8.4.3.0258:2
_403 @ dojo.js?version=V8.4.3.0258:2
_31e @ dojo.js?version=V8.4.3.0258:2
_32c @ dojo.js?version=V8.4.3.0258:2
load (async)
_325 @ dojo.js?version=V8.4.3.0258:2
xhr @ dojo.js?version=V8.4.3.0258:2
dojo.xhr @ dojo.js?version=V8.4.3.0258:2
dojo.rawXhrPost.dojo.xhrPost @ dojo.js?version=V8.4.3.0258:2
loadContent @ projeqtor.js?version=V8.4.3.0258:975
runScript @ projeqtor.js?version=V8.4.3.0258:3312
eval @ VM33281:1
JSGantt.taskLink @ jsgantt.js?version=V8.4.3.0258:2014
onclick @ main.php:1
Show 3 more frames
ckeditor.js?version=V8.4.3.0258:21 [CKEDITOR] For more information about this error go to ckeditor.com/docs/ckeditor4/latest/guide...ditor-destroy-iframe
load (async)
eval @ VM33281:1
Show 3 more frames
projeqtor.js?version=V8.4.3.0258:179 => 575ms | page='objectDetail.php' | destination='detailDiv' | formName=listForm' (server:248ms, client:327ms)
VM33360:4 Uncaught ReferenceError: assUpdateLeftWorkDirect is not defined
at Object.eval [as onChange] (eval at _functionFromScript (projeqtorDojo.js?version=V8.4.3:2), <anonymous>:4:21)
at Object.<anonymous> (projeqtorDojo.js?version=V8.4.3:2)
at dojo.js?version=V8.4.3.0258:2
eval @ VM33360:4
(anonymous) @ projeqtorDojo.js?version=V8.4.3:2
setTimeout (async)
defer @ projeqtorDojo.js?version=V8.4.3:2
_handleOnChange @ projeqtorDojo.js?version=V8.4.3:2
_278 @ dojo.js?version=V8.4.3.0258:2
_setValueAttr @ projeqtorDojo.js?version=V8.4.3:2
set @ projeqtorDojo.js?version=V8.4.3:2
assUpdateLeftWork @ projeqtorDialog.js?version=V8.4.3.0258:5107
eval @ VM33359:4
setTimeout (async)
_setBlurValue @ projeqtorDojo.js?version=V8.4.3:2
_onBlur @ projeqtorDojo.js?version=V8.4.3:2
_setStack @ projeqtorDojo.js?version=V8.4.3:2
_onTouchNode @ projeqtorDojo.js?version=V8.4.3:2
dojo.js?version=V8.4.3.0258:2 PUT projeqtor.altengroup.net/tool/saveLeftWo...Work&valueTextZone=1 403 (Forbidden)
dojo.rawXhrPut.dojo.xhrPut @ dojo.js?version=V8.4.3.0258:2
saveLeftWork @ projeqtorDialog.js?version=V8.4.3.0258:5149
eval @ VM33359:5
setTimeout (async)
dojo.js?version=V8.4.3.0258:2 _4c0 {message: "Unable to load ../tool/saveLeftWork.php?idAssign=7004&zone=AssignedWork&valueTextZone=1 status: 403", response: {…}, status: 403, responseText: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">…sion to access this resource.</p>↵</body></html>↵", xhr: XMLHttpRequest, …}message: "Unable to load ../tool/saveLeftWork.php?idAssign=7004&zone=AssignedWork&valueTextZone=1 status: 403"response: data: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">↵<html><head>↵<title>403 Forbidden</title>↵</head><body>↵<h1>Forbidden</h1>↵<p>You don't have permission to access this resource.</p>↵</body></html>↵"getHeader: ƒ _338(_339)loaded: 199options: TMP {method: "PUT", handleAs: "text", ioArgs: {…}, data: "objectClassName=Activity&creationDate=2020-05-26&l…=%20&idTargetComponentVersion=%20&nbAttachments=0"}status: 403text: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">↵<html><head>↵<title>403 Forbidden</title>↵</head><body>↵<h1>Forbidden</h1>↵<p>You don't have permission to access this resource.</p>↵</body></html>↵"total: 199transferType: "download"url: "../tool/saveLeftWork.php?idAssign=7004&zone=AssignedWork&valueTextZone=1"xhr: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}__proto__: ObjectresponseText: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">↵<html><head>↵<title>403 Forbidden</title>↵</head><body>↵<h1>Forbidden</h1>↵<p>You don't have permission to access this resource.</p>↵</body></html>↵"status: 403xhr: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}stack: "Error: Unable to load ../tool/saveLeftWork.php?idAssign=7004&zone=AssignedWork&valueTextZone=1 status: 403↵ at new _4c0 (projeqtor.altengroup.net/external/dojo/d...V8.4.3.0258:2:128459)↵ at _3fc._31e [as handleResponse] (projeqtor.altengroup.net/external/dojo/d...=V8.4.3.0258:2:85907)↵ at XMLHttpRequest._32c (projeqtor.altengroup.net/external/dojo/d...=V8.4.3.0258:2:86343)"__proto__: Error
_3da @ dojo.js?version=V8.4.3.0258:2
reject.errback @ dojo.js?version=V8.4.3.0258:2
_415.reject @ dojo.js?version=V8.4.3.0258:2
load (async)
eval @ VM33359:5
setTimeout (async)
Show 3 more frames
29 May 2020 09:47 #10 by babynus
Logged error is explicit : your server refuses acces to the resource (../tool/saveLeftWork.php)
If it is not file access rights, it must be some apache configuration that restricts access to this file.
Maybe apache log file can tell you more.
The following user(s) said Thank You: pipobru
03 Jun 2020 08:13 #11 by pipobru
it's ok now. My system administrator have change the rules in Apache configuration.
Bruno.
