ProjeQtOr free project management software - Direct acces to projects - Page 3 - ProjeQtOr
03 Jan 2012 19:30 #13 by Liolic
Copy of a log file:
2012-01-01 18:25:02 ===== TRACE ===== NEW CONNECTED USER 'olivier'
2012-01-01 18:47:09 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 18:49:32 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 19:09:46 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 19:09:59 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 21:35:15 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 21:46:13 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 21:46:26 ===== TRACE ===== NEW CONNECTED USER 'olivier'
2012-01-01 21:52:09 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 21:52:26 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 21:54:33 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 21:55:06 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 22:02:44 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 22:03:25 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 22:15:06 ===== TRACE ===== DISCONNECTED USER 'Olivier'
2012-01-01 22:15:21 ===== TRACE ===== NEW CONNECTED USER 'bragoni'
2012-01-01 22:16:19 ===== TRACE ===== NEW CONNECTED USER 'Olivier'
2012-01-01 22:19:03 ===== TRACE ===== DISCONNECTED USER 'Bragoni'
2012-01-01 22:19:19 ===== TRACE ===== NEW CONNECTED USER 'bragoni'
Nothing more. All log files are identical (only date and hour changes)
05 Jan 2012 13:19 #14 by babynus
I registered this issue as ticket #523.
09 Jan 2012 19:13 #15 by babynus
I investigated about the blank alert.
It seems that a statement echos some data, without any reason.
Can you check that :
1) Content of /tool/checkAlertToDisplay.php is exactly :
<?php
// Artefact to avoid scriptLog display even if debugLog=4. Comment the line to have it displayed again.
$noScriptLog=true;
require_once "../tool/projector.php";
if (! array_key_exists('user',$_SESSION)) {
	echo "noUser";
	return;
$user=$_SESSION['user'];
$crit=array('idUser'=>$user->id,'readFlag'=>'0', 'idle'=>'0');
$alert=new Alert();
$lst=$alert->getSqlElementsFromCriteria($crit, false, null, 'id asc');
if (count($lst)==0) {
	return;
$date=date('Y-m-d H:i:s');
foreach($lst as $alert) {
	if ($alert->alertDateTime<=$date) {
	  echo '<b>' . htmlEncode($alert->title) . '</b>';
	  echo '<br/><br/>';
	  echo  $alert->message;
	  echo '<input type="hidden" id="idAlert" name="idAlert" value="' . $alert->id . ' " ./>';
	  echo '<input type="hidden" id="alertType" name="alertType" value="' . $alert->alertType . '" ./>';
	  return;
2) there is no "echo" in your parameter.php file.
3) There is no actie "echo" command in /model/persistence/SqlElement.php
4) Check that you did not add an "echo" command in /tool/projector.php file or other file
09 Jan 2012 20:15 #16 by Liolic
I checked all files as you asked me:
is exactly as you described.
there are no echo command in this file.
3) There is no active "echo" command in /model/persistence/SqlElement.php
All "echo" commands are like commentaries
//echo
or
/*echo
here are all echo commands:
if ( ! is_file($parametersLocation) ) {
    echo "*** ERROR ****<br/>";
    echo " parameter file not found at '" . $parametersLocation . "'<br/>";
    echo " Check file '/tool/parametersLocation.php' or remove it to use '/tool/parameters.php'.<br/>";
    echo " <br/>";
    echo " If problem persists, you may get some help at the forum at <a href='http://projector.toolware.fr/'>projectOr web site </a>.";
    exit;
______________________________________________________________
if (is_file("login.php")) {
      include "login.php";
    } else {
      echo '<input type="hidden" id="lastOperation" name="lastOperation" value="testConnection">';
      echo '<input type="hidden" id="lastOperationStatus" name="lastOperationStatus" value="ERROR">';
      echo '<span class="messageERROR" >' . i18n('errorConnection') . '</span>';
    exit;
if ( $changePassword ) {
		      if (is_file("passwordChange.php")) {
		        include "passwordChange.php";
		      } else {
		        echo '<input type="hidden" id="lastOperation" name="lastOperation" value="testPassword">';
		        echo '<span class="messageERROR" >' . i18n('invalidPasswordChange') . '</span>';
		      exit;
function throwError($message, $code=null) {
	global $globalCatchErrors;
  echo '<span class="messageERROR" >ERROR : ' . $message . '</span>';
  echo '<input type="hidden" id="lastSaveId" value="" />';
  echo '<input type="hidden" id="lastOperation" value="ERROR" />';
  echo '<input type="hidden" id="lastOperationStatus" value="ERROR" />';
  if (! $globalCatchErrors) {
    exit();
if ( ! file_exists($dir) ) {
      echo '<br/><span class="messageERROR">' . i18n("invalidLogDir",array($dir)) . '</span>';
    } else if ( ! is_writable($dir)) {
      echo '<br/><span class="messageERROR">' . i18n("lockedLogDir",array($dir)) . '</span>';
    } else {
      writeFile( $msg,$file);
The others are like commentaries
//echo
I added nothing by myself. The oly transformations that I did are in lang. file,
$firstPage="planningMain.php";
in main.php file, change the menu order in tables and finally as you asked me, I changed the receivers list (checkboxes) in "Parameters"/"Controls & automations"/"Indicators" - and deleted old messages.
Perhaps I can send to you all my php files. I did not upgrade yet to the new version, as I had no time.
That's all.
Thank you for your help.
Best regards,
Olivier
10 Jan 2012 09:38 #17 by babynus
Here is just a workaround.
Replace in /view/js/projectorDialog.php
function checkAlertRetour(data) {
  if (data) {
	var reminderDiv=dojo.byId('reminderDiv');
	var dialogReminder=dojo.byId('dialogReminder');
	reminderDiv.innerHTML=data;
	//dojo.parser.parse(reminderDiv);
	dojo.style(dialogReminder, {visibility:'visible', display:'inline', bottom: '-200px'});
	//alertDisplayed=true;
	var toColor='#FFCCCC';
    if (dojo.byId('alertType') && dojo.byId('alertType').value=='WARNING') {
		toColor='#FFFFCC';
	if (dojo.byId('alertType') && dojo.byId('alertType').value=='INFO') {
		toColor='#CCCCFF';
	dojo.animateProperty({
        node: dialogReminder,
        properties: {
            bottom: { start: -200, end: 0 },
            right: 0,
            backgroundColor: { start: '#FFFFFF', end: toColor }
        duration: 2000
    }).play();
  } else {
	setTimeout('checkAlert();',alertCheckTime*1000);
with
  if (data) {
	if (dojo.byId('alertType')) {
			toColor='#FFFFCC';
			toColor='#CCCCFF';
	        properties: {
	            right: 0,
	        duration: 2000
	    }).play();
  } else {
if this fixes the issue, it will be included in V2.0.
12 Jan 2012 01:06 #18 by Liolic
Hi Babynus,
There is no such files
but I foud a
/view/js/projectorDialog.js
so I tried to modify this file and it seems that alerts have disapeared.
It seems that you got it!
I you think that version 2.0 will be ready soon, I will wait to upgrade and forget the 1.9.1 version that seems not to be a major update. The 1.9.0 works fine for me now.
Thanks for your help.
Best regards,
Liolic
