ProjeQtOr free project management software - Gestion de X société avec X projet - ProjeQtOr
22 Feb 2021 17:04 - 24 Feb 2021 11:09 #1 by EPC
[French version, English version after]
Bonjour,
J'aimerais savoir si il est possible dans l'outil de gérer plusieur entité différente ?
Exemple :
  • Société 1
    • Projet A
    • Projet B
    • ect...
  • Société 2
    • Projet A
    • Projet B
    • ect...
  • etc...
Bonne journée à vous.
[English version]
I would like to know if it is possible in the tool to manage several different entities?
  • For example :
  • Company 1
    • Project A
    • Project B
    • ect...
  • Company 2
    • Project A
    • Project B
    • ect...
  • etc...
Good day to you.
Last edit: 24 Feb 2021 11:09 by EPC.
24 Feb 2021 08:51 #2 by Arkhanje
If you follow the rules of the forum then promise, we will answer you!
24 Feb 2021 11:10 #3 by EPC
Sorry, I just corrected.
26 Feb 2021 14:27 #4 by babynus
Yes, you can, several ways possible
1) use projet object for structure, so Company 1 and Company 2 are projects containing sub-projects.
2) use Organization : you then need to have Project A - Main, then Project A1 linked to Organization 1 and Project A2 linked to Organization 2
3) Don't care about splitting, just use resources from different comanies (as defined on resource as organization or team), then you'll get reports per orgnaisation or team
26 Feb 2021 17:00 #5 by EPC
Ok, thank you for your feedback. It's going to be a great tool.
Thanks for your help.
Reagrds,
EPC
