ProjeQtOr free project management software - Droit Module Import Projet sur Problem 9 / Law Module Import Project on V9 - ProjeQtOr
03 Mar 2021 20:44 #1 by ADOSI
Bonsoir,
Nous avons acquis le module d'import Projet et nous constatons lors du passage sur Projeqtor V9 qu'il est impossible de gérer les droits d'accès selon le profil.
Malgrès le paramétrage de la V8 qui fonctionnait cela ne marche plus en V9.
Pouvez vous nous aider?
Merci de votre réponse.
Cordialement
Good evening,
We have acquired the Project import module and we notice when switching to Projeqtor V9 that it is impossible to manage the access rights according to the profile.
Despite the setting of the V8 which worked, it no longer works in V9.
Can you help us?
Thank you for your reply.
cordially
06 Mar 2021 11:10 #2 by babynus
The rights can still be configured, but users with new interface don't see the menu.
You can swith to old interface to retreive the menu.
This is an issue that we fixed on V9.0.5.
THe access may have moved to "plugin" menu.
We'll publish a fix on the plugin to get all thinks back.
