ProjeQtOr free project management software - Document Reference Format - Keywords ? - ProjeQtOr
06 Jul 2021 09:14 #1 by cem
Hello all,
Are there any specific Document Reference Format keywords other than, PROJ, TYPE, NUM, NAME and VERS ?
I'm looking for a keyword for Document Location or Directory ?
Thanks,
Cem
08 Jul 2021 10:02 #2 by Arkhanje
We only offer these.
The difficulty is that, if a field is used to establish the reference, it must be mandatory and ProjeQtOr offers few mandatory fields as standard.
ProjeQtOr is not meant to be binding.
The following user(s) said Thank You: cem
09 Jul 2021 10:23 #3 by cem
Ok, I understand. Thank you.
I also find out that {PROD} is also a keyword, which is not stated on the online manual. That is why I asked if there is any more related with Document Reference.
BR,
Cem
20 Jul 2021 08:54 - 20 Jul 2021 11:10 #4 by Arkhanje
After investigation, there are indeed other tags for product references only.
On the other hand, for your request concerning a keyword for Document Location or Directory, we do not have anything existing.
Last edit: 20 Jul 2021 11:10 by Arkhanje.
