ProjeQtOr free project management software - [SOLVED] Schedule Report Issue - ProjeQtOr
27 Aug 2021 06:46 #1 by Shalika
Hi
I tried to create Schedule reports and reports are generated properly but there is no data.
Please help me
27 Aug 2021 09:21 #2 by Arkhanje
Replied by Arkhanje on topic Schedule Report Issue
Can you be more precise. Which report is concerned exactly. Because for the planning, we offer more than twenty.
What data is not displayed if the report is generated correctly?
Can you attach a capture?
27 Aug 2021 09:54 #3 by Shalika
Replied by Shalika on topic Schedule Report Issue
hi
I tried to generate Detailed work per resource - monthly reports and it generated and sent an email as below
27 Aug 2021 11:01 #4 by Arkhanje
Indeed no data ...
It might sound silly, but is there really any real work in this time for this team?
Have you checked that your parameters (organization, team, year, month) are not too restrictive for you? Do you have reading rights on this organization? on this team?
If this is an error, there is a good chance that it is indicated in your log file. Also check this option.
On our side we do not produce any errors.
09 Sep 2021 21:16 #5 by anilherath
Replied by anilherath on topic Schedule Report Issue
We are having the same issue. These are the steps to reproduced the issue.
01. Start Cron
02. Go to : Reports -> Real Work -> Detailed work per resource - monthly -> set organization, team and the month ( attached SS 01)
03. Check the report on screen : Shows data ( attached SS 02)
04. Check the PDF : Shows data ( attached Report 01.pdf)
05. Schedule the report : set Current year, Previous month, Every day, time and other receivers email  ( attached SS 03)
06. Email Received with PDF : PDF shows only the parameters and says no data available ( attached SS 04)
This browser does not support PDFs. Please download the PDF to view it: Download PDF
09 Sep 2021 21:24 - 10 Sep 2021 10:03 #6 by anilherath
We are facing the same issue. This is steps we followed to
This duplicate comment was sent accidently. Sorry for the inconvenience happened.
Last edit: 10 Sep 2021 10:03 by anilherath. Reason: duplicated comment
