ProjeQtOr free project management software - Problem using Projeqtor API - Page 2 - ProjeQtOr
01 Dec 2021 21:02 #7 by fsouliers
I had the same problem, you can find a part of a solution here :
www.projeqtor.org/fr/forum-fr/2-submit-i...yption?start=6#31201
using it, the API works really great (an it is so helpful to give projeqtor the possibility to interact with other softwares).
@babynus, I would be really pleased to improve the API, I would just like to talk about the way you want to integrate things (posting a zip is not so useful).
Hope this helps,
