ProjeQtOr free project management software - issues for export from ProjeQctor to xml project - ProjeQtOr
21 Sep 2022 14:48 #1 by DIEGO ROJAS
     Hi every body, i have found a little bit issues for export from ProjeQtor to xml project, i don't know what happened, the duration does not export the right mode. i m talking about of schedule (Gantt) module. So, its to importat fix that, because the patch 10.0.6 is ok. In the version 10.1.0 is the problem.
22 Sep 2022 10:35 #2 by babynus
Ticket recorded
04 Oct 2022 11:37 #3 by babynus
Cannot reproduce.
Project in Projeqtor, exported to xml/MS-Project format
is correctly imported on Project Libre
and on MS-Project
Please check you correctly export Assignments to MS-Project format (check user parameters)
