ProjeQtOr free project management software - [SOLVED] Sauvegarde interface - ProjeQtOr
15 Feb 2023 16:05 - 20 Feb 2023 09:32 #1 by fbrette
Sauvegarde interface was created by fbrette
Good morning,
Sorry i dont speak english. So i use google translate !
User of ProjeQtor V9.5.5 I have correctly customized my interface. I have happened to activate by mistake a menu or a display that I did not want, so my question is as follows: is it possible for me to save my personalized interface and reload it if I modify it by mistake in order to always have a backup? Is it a localizable file and if so where can I find it to keep or make a copy? Waiting for your help, Thank you in advance.
Bonjour,
Utilisateur de ProjeQtor V9.5.5 j'ai correctement personnalisé mon interface. Il m'est arrivé d'activer par erreur un menu ou un affichage que je ne souhaitais pas ma question est donc la suivante : m'est il possible de sauvegarder mon interface personnalisée et de la recharger si je modifie par erreur cette dernière afin d'avoir toujours une sauvegarde ? Est ce un fichier localisable et si oui où puis je le trouver pour le conserver ou en faire une copie ?
Dans l'attente de votre aide,
Par avance merci.
Last edit: 20 Feb 2023 09:32 by fbrette.
18 Feb 2023 00:59 #2 by babynus
Replied by babynus on topic Sauvegarde interface
PLEASE RESPECT FORUM RULES - WRITE IN ENGLISH
20 Feb 2023 09:33 - 20 Feb 2023 11:41 #3 by fbrette
Replied by fbrette on topic Sauvegarde interface
Good morning,
So : User of ProjeQtor V9.5.5 I have correctly customized my interface. I have happened to activate by mistake a menu or a display that I did not want, so my question is as follows: is it possible for me to save my personalized interface and reload it if I modify it by mistake in order to always have a backup? Is it a localizable file and if so where can I find it to keep or make a copy? Waiting for your help, Thank you in advance.
Last edit: 20 Feb 2023 11:41 by fbrette.
12 Apr 2023 15:50 #4 by fbrette
Is there anyone to answer me ?
13 Apr 2023 10:01 #5 by Arkhanje
Replied by Arkhanje on topic Sauvegarde interface
Hello !
we offer an auto backup plugin that allows you to make backups of your complete database automatically.visit the store to find out more about this tool.
13 Apr 2023 10:22 #6 by fbrette
Arkhanje post=35208 wrote: Hello !
