ProjeQtOr free project management software - [SOLVED] workflow start by "pause" - ProjeQtOr
23 Jun 2023 09:25 #1 by pdecloedt
to simplify planning, I would like to be able to "pause" activities as soon as they are created, so that they do not enter the load. keep the "pause" mode when they are assigned and finally release the "pause" mode when they go "in progress". I manage to do it, except for the first "saved" state where it is impossible to have the "pause" boolean active by default. could you help me ?
23 Jun 2023 09:58 #2 by babynus
Replied by babynus on topic workflow start by "pause"
Only solution will be to use the Screen Customization plugin.
Then, just define default value to "1" for objects Activity and Activity - Progress
(you have to do this on both as these values are duplicated and synchonized only through Status or Interface changes)
23 Jun 2023 10:17 #3 by pdecloedt
23 Jun 2023 10:28 #4 by pdecloedt
Replied by pdecloedt on topic workflow start by "pause"
I try with "true", It seems to work, but when I create a new activity, with first workflow "Enregistré", the "mettre en pause" is not at true value ???
I put by defaut value on true, both : Activity / "mettre en pause" and Activiy-Progress / "mettre en pause"...
23 Jun 2023 10:41 #5 by babynus
In fact, expected value in "on"
My fault, I tested and entered "on" but wrote "1" in the post.
I need a week-end...
The following user(s) said Thank You: pdecloedt
23 Jun 2023 11:07 #6 by pdecloedt
it's works thk you. But now, when i change the workflow to "assigné" it keep the "on" boolean state ...
normaly on "assigné" status, it will not on ...
