ProjeQtOr free project management software - [SOLVED] Cron for start ProjeQtOr Cron Process - ProjeQtOr
04 Aug 2023 19:22 - 16 Aug 2023 09:35 #1 by sharky
I try to put a cron that restarts the ProjeQtor cron by following this procedure:
www.projeqtor.org/en/forum/9-tips-tricks...ss-is-always-running
I created the user in ProjeQtor, secured the /api folder according to the documentation.
Create the script PHP by copying the information and adapting values: URL, user and password.
If I open the page directly in the browser: Info: Starting ProjeQtOr cron process for https://[my URL]/ Error: failed to start ProjeQtOr cron process
What questions me is that the API folder is empty for me is and in the downloaded zip.
On the other hand, the script uses API sub-folders
$fullUrl=$siteUrl."api/Cron/check";
or
$fullUrl=$siteUrl."api/Cron/start";
Is something missing?
What else can I control?
Thanks for your help
sharky
Last edit: 16 Aug 2023 09:35 by sharky.
04 Aug 2023 19:41 - 04 Aug 2023 19:41 #2 by sharky
I also tried doing a bash .sh, but I got the same error.
It was the header that gave me the idea
#!/usr/bin/php
Last edit: 04 Aug 2023 19:41 by sharky.
14 Aug 2023 18:11 #3 by babynus
Possibly access to API is wrong.
Check htaccess...
14 Aug 2023 20:00 #4 by sharky
Thank you.
I have try : remove login, comment in .htaccess
# AuthUserFile "./.htpasswd"
# AuthName "Projets"
# AuthType Basic
# require valid-user
Result
{"error":"invalid API query", "message":""user '' unknown in database""}
I created the user with the same password in my ProjeQtor instance
But I can't access the api folder
I created the .htpasswd using the command
htpasswd -c -B .htpasswd CronJobTask
I also tested with a generator
www.web2generators.com/apache-tools/htpasswd-generator
Same issue
Warning: Spoiler!
other ideas
14 Aug 2023 20:17 #5 by sharky
Yes !
With full path .htapasswd in .htaccess ;)
