ProjeQtOr free project management software - Help Needed: Planned Days Reduced After Adding Activities - ProjeQtOr
29 Jun 2024 07:57 #1 by cdhamilton
Hi ProjeQtOr Community,
I'm a new user and I'm encountering an issue with my project's planned days. Here are the details:
- I set my project start date to 1st July 2024 and end date to 1st July 2025, resulting in a validated duration of 262 days.
- I created a resource and added a couple of activities. These activities are assigned to the project, but I did not specify start/end dates for them.
- For some reason, the "planned" days for the project adjusted to 92, which is significantly less than the validated days.
I’ve reviewed all settings and configurations multiple times but can't identify the cause of this adjustment. Could anyone provide insight into what might be causing this issue or suggest any steps to resolve it?
Thank you for your assistance!
Best regards,
Craig
01 Jul 2024 09:09 #2 by babynus
IT is just because it is not the duration of the project that will determine the duration of tasks.
It is reversed.
Duration of tasks will determine the duration of the project.
PorjeQtOr is not just a drwing tool.
It calculates a realistic capacity planning depending on resources capacity.
