ProjeQtOr free project management software - Leaves in worload plan - ProjeQtOr
22 Jul 2024 17:36 #1 by GregoLid
Hello everyone,
I want to manage leaves using the 'regulated leaves' module.
Is it normal for the project created automatically by the module (named PROJECT - LEAVE PERIOD) to be invisible in the 'projects' section?
Leaves are not represented in the 'planning > critical resources' section, 'workload plan' tab. Absences could affect either the forecasted load (colored bars) or the resource's capacity, don't you think?
By the way, a very rich tool, well done!
The following user(s) said Thank You: Arkhanje
23 Jul 2024 08:01 #2 by Arkhanje
Replied by Arkhanje on topic Leaves in worload plan
Is it normal that the project automatically created by the module (named PROJECT - HOLIDAY PERIOD) is invisible in the 'projects' section?
yes, this is the expected behavior.
As for critical resources, this is a sponsored development. Do not hesitate to ask for a quote to improve this feature
