ProjeQtOr free project management software - Invisible “on pause” project - ProjeQtOr
03 Feb 2025 09:25 #1 by pdecloedt
hello,
Would it be possible to make projects that are in "paused" status invisible as it is possible to do with closed elements?
By a display trick or by customizing the workflow?
03 Feb 2025 09:40 #2 by Arkhanje
no. We have not planned this option.
It is not planned on the roadmap either.
But you can contact us to sponsor this evolution!
04 Feb 2025 09:39 #3 by jmmbb
You can also use custom filters an, for example, name it "mask paused projects".
The following user(s) said Thank You: Arkhanje
04 Feb 2025 09:44 #4 by pdecloedt
Yes but if only the project is on "paused" and if there is some other element no on paused (activity for example) the project is not masked...
