ProjeQtOr free project management software - [SOLVED] project based monthly timesheet export - ProjeQtOr
27 Mar 2025 22:55 #1 by fsobel
Hello everyone !
any smart way to export monthly timesheets per project and per ressource in csv format or others different from any image type formats ?
With kind Regards,
31 Mar 2025 10:14 #2 by Arkhanje
You can export your resource timesheets using the timesheet tools.
The timesheet is unfortunately the only screen that cannot be sorted by project. All assignments for a resource are systematically displayed.
Maybe try reducing the display with the filter "items not started" ...
The following user(s) said Thank You: fsobel
