ProjeQtOr free project management software - Is it possible to have Kanban per project - ProjeQtOr
21 Oct 2025 16:46 #1 by LEADER
Is it planned to implement Kanban per project. As I see (perhaps i am wrong), we can define multiple Kanban but not per project. Is is good to manage a portfolio but if for example, we want to manage multiple differents columns projets per projects, it is not possible.
Best regards,
24 Oct 2025 09:50 #2 by babynus
It is a planned evolution (ticket #673).
Not planned on a version yet.
We estimated the cost for a client that could sponsor this evolution, but finaly he did not validate the quote.
So evolution is still in low priority.
The following user(s) said Thank You: LEADER
31 Oct 2025 15:45 #3 by LEADER
Thank you for your answer. If it is not planned currently to create Kanban for individual project, is it planned to offer the possibility (add to the selector list)to select project as the same as ticket, activity, actions, requirements.
26 Nov 2025 09:35 #4 by babynus
Yes, it already works this way.
Selection in the project selector is applied to Kanban items.
You can alos define as many Kanban boards as you want, so you can define a Kanban for each layout you want.
Only things you cannot do :
 - have a Kanban of projets (items are projetcs) - This is subject of ticket #673
 - automatically apply a Kanban when you select a projet (subject of your initial request)
06 Dec 2025 08:40 #5 by LEADER
Thank you for your answer. I will check the possibilities offered.
