ProjeQtOr free project management software - v2.2.0:: AutoMail Issue - Page 3 - ProjeQtOr
03 Aug 2012 11:48 #13 by babynus
Replied by babynus on topic Re: v2.2.0:: AutoMail Issue
The issue may come from 2 points :
1) the smtp server used by PHP to sent the mail.
In most cases (by default), it is the sendmail program, but you may change it.
Default parameters of sendmail work fine, but these may also have been changed on your side.
2) the mail server of your company, that manages your mailbox (Lotus server ?)
This server is able to filter and transform your mails (for security reasons)
Test you can do :
On your Project'Or RIA application, try to send an email to a remote mail, such as a webmail not depdending on your company (for instance @gmail.com, or your can send it to me - This email address is being protected from spambots. You need JavaScript enabled to view it.)
If mail is wrong = it is your smtp server used by PHP that must be fixed
If mail is correct = you are facing some transformation from your company mailing system. Contact the administrator of this service.
03 Aug 2012 15:22 #14 by gvecchi
Replied by gvecchi on topic Re: v2.2.0:: AutoMail Issue
Postfix seems to be the problem: I uninstalled it and installed sendmail and HTML emails now work.
I need to find out why postfix doens't let me to correctly realy HTML emails.
Stay tuned ;)
03 Aug 2012 15:42 #15 by gvecchi
The problem is a postfix bug: stackoverflow.com/questions/3449431/php-...-break-html-email-in
For the moment, I can't uninstall current version of postfix (2.7 on Ubuntu 10.04) so I solved modifing tool/projector.php from line 582 to 586
 if (!$headers) {
    $headers  = 'MIME-Version: 1.0' . "\n";
    $headers .= 'Content-type: text/html; charset=utf-8' . "\n";
    $headers .= 'From: ' . (($sender)?$sender:$paramMailSender) . "\n";
    $headers .= 'Reply-To: ' . (($sender)?$sender:$paramMailReplyTo) . "\n";
    $headers .= 'Content-Transfer-Encoding: 8bit' . "\n";
    $headers .= 'X-Mailer: PHP/' . phpversion();
03 Aug 2012 16:16 - 03 Aug 2012 16:56 #16 by babynus
I just changed the code to :
if (!$headers) {
    $eol=(isset($paramMailEol))?$paramMailEol:"\r\n";
    $headers  = 'MIME-Version: 1.0' . $eol;
    $headers .= 'Content-type: text/html; charset=utf-8' . $eol;
    $headers .= 'From: ' . (($sender)?$sender:$paramMailSender) . $eol;
    $headers .= 'Reply-To: ' . (($sender)?$sender:$paramMailReplyTo) . $eol;
    $headers .= 'Content-Transfer-Encoding: 8bit' . $eol;
This way, you'll just have to define
$paramMailEol="\n";
in the parameters.php file, and your config will always be valid, even if you deply new version.
Will be deployed in V2.4.2.
Last edit: 03 Aug 2012 16:56 by babynus.
The following user(s) said Thank You: gvecchi
03 Aug 2012 16:28 #17 by gvecchi
Really good.
09 Aug 2012 08:20 #18 by gvecchi
Do you mean files/config/parameters.php or tool/parameters.php ?
