ProjeQtOr free project management software - Installation process doesn't work. - ProjeQtOr
05 Sep 2012 14:12 #1 by mseuda
Hi all.
I try to install Projector but install process don't work.
The OK button don't work.
No log generated.
Help
I try to create the file parametersLocation.php but don't work too..
05 Sep 2012 16:48 #2 by babynus
On which screen ? What is the exact behaviour ?
On the config screen, OK button makes a new button appear under the OK button.
Depending on screen resolution, if OK button is on bottom of screen, you may not see this new button (a scroll bar should appear on the window).
Otherwise, could you check for javascript errors ?
The following user(s) said Thank You: mseuda
05 Sep 2012 17:09 - 05 Sep 2012 17:11 #3 by mseuda
Hi
When i click on the ok button nothing happend in the configuration screen. The first screen before the first connection. The database is not created.
The spinner is displayed during 1 second and nothing after...
No scroll bar in the bottom, no warning message, no javascript error, and no log.
version : 2.4.3
Red Hat 5.6, 64bit
Apache/2.2.3
PHP 5.3
Mysql 5.0.85
Last edit: 05 Sep 2012 17:11 by mseuda.
05 Sep 2012 17:26 #4 by babynus
If spinner disepears, then you must have something.
(answer is received from server)
Can you try to drag the window down (as if you wanted to select all the text in the window) to try and have new button appear.
05 Sep 2012 17:50 - 05 Sep 2012 17:54 #5 by mseuda
I do, but same thing... Nothing happend.
No new button appear, sorry
And no new button in html code.
Is not possible to activate some logs ?
Last edit: 05 Sep 2012 17:54 by mseuda.
05 Sep 2012 19:40 #6 by babynus
Unfortunatly, is you did not finish the config phase, no applicative log can be fetched.
Can you please open a browser with dev tools (Chrome, or Firefox with firebug extension) and trace the response to resquest send on "OK" click.
Please post it here.
