ProjeQtOr free project management software - How To describe a Project - ProjeQtOr
14 Sep 2012 17:56 #1 by pmagnin
Hi
Is it possible to finely describe a project?
I wish for each project, create a description by filling custom predefined values fields.
For example:
* technology = (32b, 64b).
* OS (windows, linux, mac ..)
* Language (java, php, # net, ...)
I would then filter the projects by these criteria.
thank you
14 Sep 2012 19:48 - 14 Sep 2012 19:48 #2 by babynus
There is no specific fields to enter these description.
But you can simply use Description field, just normalizing it.
technology=64b
OS=Windows
Language=Java
Then you'll be able to create new project filter suach as "description contains 'Language=Java'" to see all you java projects.
Another way can be to define new project types, but you'll have to multiplicate types for each possible combination of custom description.
Last edit: 14 Sep 2012 19:48 by babynus.
14 Sep 2012 20:00 #3 by pmagnin
Ok, thanks.
I will check the project type solution.
can I set a new project type to an existing project ?
Philippe
14 Sep 2012 20:10 #4 by babynus
Yes.
