ProjeQtOr free project management software - display activities/tasks of project - ProjeQtOr
11 Feb 2011 14:27 #1 by sa
I want to display the list of project activities and all activities of the subprojects.
The filter does not allow it.
Can you tell me how to do
Thank you
11 Feb 2011 15:18 #2 by babynus
Just select the project in the combo above the menu list (top left).
All items (activites, tickets, ...) will then be restricted to the project and its sub-projects.
You can also define the "defaut projet" on user parameters so that it is automatically defined on each new connection.
Regards.
11 Feb 2011 16:09 #3 by sa
The combo of the menu list (top left) works well with InternetExplorer but there is no action with firefox.
Best regards
11 Feb 2011 20:12 #4 by babynus
Bug confirmed for Firefox.
Registered as Ticket #302.
