ProjeQtOr free project management software - How to create a ComboBox - ProjeQtOr
30 Nov 2012 17:02 #1 by a.mikael
how to create à ComboBox in Projectoria ?
I have my class Milestone who extends to SqlElement and my field "clarety".
I have create in the table "milestone" on my DB the field "clarety" who is a "tinyint" and i have add this line in the class Milestone :
public $test
So, in projectoria when i open a milestone my field clarety is created but is a textfield.
How to change this textfield in combobox ?
30 Nov 2012 18:30 #2 by babynus
Project'Or RIA framework is "explicit", non desciptive. :evil:
To get a combobox, you need :
- name the field "idClarety"
- define idClarety in db, with format int(12).
- define table clarety, with at least "id" int(12) and "name" varchar(100)
- define class Clarety.php, mapping clarety table.
All the rest is automatic :woohoo:
03 Dec 2012 11:10 #3 by a.mikael
Now, i see the combo Clarety but is empty :S
I Have create table clarety
I have add idClarety in Milestone with index
I have add
public $idClarety;
in Milestone.php
I have add class Clarety.php in model\ :
<?php
 * Client is the owner of a project.
class Clarety extends SqlElement {
  // extends SqlElement, so has $id
  public $id;    // redefine $id to specify its visiblez place
  public $name;
  private static $_databaseTableName = 'clarety';
  //public $_isNameTranslatable = true;
   * Constructor
   * @param $id the id of the object in the database (null if not stored yet)
   * @return void
  function __construct($id = NULL) {
    parent::__construct($id);
   * Destructor
   * @return void
  function __destruct() {
    parent::__destruct();
// GET STATIC DATA FUNCTIONS
03 Dec 2012 11:36 #4 by babynus
Just fill in Clarety table with some data ... ;)
03 Dec 2012 11:38 #5 by a.mikael
No, i have add two lines :
1 - YES
2 - NO
03 Dec 2012 11:46 #6 by babynus
Check log file for errors.
Remove this line, no use if table name=class name
Uncomment this line, YES/ NO will be translated.
