ProjeQtOr free project management software - Zend Serveur and DoJo - Page 2 - ProjeQtOr
02 Jan 2013 19:42 #7 by babynus
Replied by babynus on topic Re: Zend Serveur and DoJo
1) the progress bar will only be displayed if you have real work.
The progress is displayed as %, correponding to % of the total size of the bar.
So if your activity started in the past, you may not see the progress unless you change the start date todisplay the planning.
2) If you try to display more than a hundred lines in the gant planning, it will be very long to display (the javascript part to build the gantt).
You wayselect to continue, it should display the gantt in the end.
Nb : Chrome provides best performance on the side.
02 Jan 2013 21:37 #8 by JCDe
Replied by JCDe on topic Re: Zend Serveur and DoJo
Thanks but this is the number of rows to display which triggers this bug (erreur script dojo:15 ?)
02 Jan 2013 22:52 #9 by babynus
No, issue should not come from number of lines.
It should come from some Data.
Could you try :
- open plannng page untl you get the error
- open a new tab in the smae instance of brower and request for
http://your_server/your_projectorria/tool/jsonPlanning.php
- send me the result : the exact source code, not a print of the display in the browser.
