ProjeQtOr free project management software - Need help to send Mails - Page 2 - ProjeQtOr
20 May 2011 11:00 #7 by babynus
So, you ust set :
$paramMailSmtpServer = 'smtp.auth.orange-business.com';
$paramMailSmtpPort = '587';
$paramMailSendmailPath = '';
If mailing does not work with these parameters, it is probably because this smtp server requires authentication on connection.
So way to solve would be :
- try another smtp server (for instance smtp.free.fr does not require autentication...)
- set-up your own smtp server on your host (and set $paramMailSmtpServer='localhost')
Babynus.
20 May 2011 12:12 #8 by Bakura
Replied by Bakura on topic RE : Need help to send Mails
And i can't put my authentication 's connection on my file's configuration sendmai.mc?
20 May 2011 16:04 #9 by babynus
I don't understand.
If you have a sendmail.mc, you have a sendmail installed : so you have your own smtp server !
Why try and use and external one ?
Just use your local smtp server :
$paramMailSmtpServer = ''; (keep it blank or maybe 'localhost' or '127.0.0.1')
$paramMailSmtpPort = ''; (keep it blank, default value is '25', check your sendmail config)
$paramMailSendmailPath = ''; (keep it blank if sendmail is set-up at default location, otherwise, indicate sendmail path)
Regards.
Babynus.
