ProjeQtOr free project management software - Join between tables - ProjeQtOr
Join between tables
27 Mar 2013 11:25 #1 by imenkolsi
Hi again,
I'de like to join between n tables
I want to do with just one query that will returns all the result
For example between the table resource and the table work
i'd like to get for each resource its work
I don't want to have many queries : one to get all the resources and another query to
get the work for each one.
Would u help me ?
27 Mar 2013 11:30 #2 by babynus
Replied by babynus on topic Re: Join between tables
Something like this ?
select resource.fullname, sum(work.work)
from resource, work
where resource.id=work.idResource
group by resource.fullname
27 Mar 2013 11:39 #3 by imenkolsi
Replied by imenkolsi on topic Re: Join between tables
Actually i'm looking for something like this
SELECT r.id, r.fullname, r.email, w.work
FROM resource r
LEFT JOIN WORK w ON r.id = w.idResource
GROUP BY r.name
Could u tell me how can i get this one with one from your sql methods ?
other wise, can i use directly this query on the code ? if yes would u tell me
how ?
27 Mar 2013 11:50 #4 by babynus
$query='SELECT r.id, r.fullname, r.email, w.work'
.' FROM resource r'
.' LEFT JOIN WORK w ON r.id = w.idResource'
.' GROUP BY r.name';
$result=Sql::query($query);
27 Mar 2013 12:01 #5 by imenkolsi
Thank you :) every thing works really fine
